Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone. Pull the white portion of the strip when possible, the black tab may fall off. Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
  • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  • Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone. Pull the white portion of the strip when possible, the black tab may fall off.
  • Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
  • Be careful not to snag it on any of the other internal iPhone components.
  • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
Intenta de mantener las tiras planas y desarrugadas durante este procedimiento; las tiras arrugadas se pegarán juntas y se romperán en vez de salir limpiamente.
Lentamente jala una de las tiras de adhesivo de batería hacia el inferior del iPhone.
Jala constantemente, manteniendo una tension constante en la tira mientras se desliza entre la batería y la caja trasera. Para mejores resultados, jala la tira a un ángulo de 60º o menos.
Guía la tira cuidadosamente alrededor de la esquina y hacia el lado superior de la batería. Ten cuidado de no enganchar la tira en otros componentes de iPhone internos.
La tira se estirara varias veces su tamaño original. Continua tirando, agarrando la tira cerca de la batería si es necesario, hasta que la tira entera sea liberada.
