Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab. Important: Apply heat to the bottom of the iPhone case using an iOpener or similar heating pad to soften up the battery adhesive strips and make them more flexible, otherwise they will probably break when you pull on them. Important: Apply heat to the bottom of the iPhone case using an iOpener or similar heating pad to soften up the battery adhesive strips and make them more flexible, otherwise they will probably break when you pull on them.
  • Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab.
  • Important: Apply heat to the bottom of the iPhone case using an iOpener or similar heating pad to soften up the battery adhesive strips and make them more flexible, otherwise they will probably break when you pull on them.
Corre la punta de un spudger entre la bateria y la entrada de auriculares para desplegar la etiqueta de adhesivo de bateria.
Importante: Aplica calor a la parte de atrás de la carcasa del iPhone usando iOpener o similar, para aflojar las tiras de adhesivo y hacerlas más flexibes, en caso contrario se podrían romper cuando tires de ellas.
