Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 7
Paso 7
When finished, the blade's edge should look like the blade in the first picture. It should be beveled at a constant angle and generally will look uniform when viewed from different angles in the same light. As a comparison, the blade before being sharpened can be seen in the second picture.
  • When finished, the blade's edge should look like the blade in the first picture. It should be beveled at a constant angle and generally will look uniform when viewed from different angles in the same light.
  • As a comparison, the blade before being sharpened can be seen in the second picture.
  • This is actually the same exact portion of the blade.
  • Be sure to wash your knife before you cut up any food, and watch your fingers! A freshly sharpened knife will be extremely sharp if you've done the process right.
Insertar traducción aquí
