Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Holandés
Paso 4
The heat sink is firmly adhered to the fan.
  • The heat sink is firmly adhered to the fan.
  • Use a Phillips screwdriver to remove three 2.4 mm screws securing the fan.
  • Use a T5 Torx screwdriver to remove the final 4.4 mm screw securing in the fan cover.
Verwijder de 1.5 mm lange Torx T4 schroef die de pijpjes van het koellichaam aan het frame van het toestel bevestigen.
Verwijder de 3.0 mm lange Torx T4 schroef.
-[* red] Remove the 1.5mm Torx T4 screw holding the heat sink tubing to the frame of the device.
-[* orange] Remove the 3.0mm Torx T4 screw.
+[* icon_note] The heat sink is firmly adhered to the fan.
+[* red] Use a Phillips screwdriver to remove three 2.4 mm screws securing the fan.
+[* orange] Use a T5 Torx screwdriver to remove the final 4.4 mm screw securing in the fan cover.
