Saltar al contenido principal
Inglés
Español
Paso 4
Lift the car enough to place a jack stand underneath a flat portion of the frame rail just behind the control arm bushing. Gently allow the car to fall onto the jackstand, lifting the car and re-adjusting its position as necessary. Once all of the weight has been transferred to the jack stand, tighten the release plug on the jack and leave it positioned under the jack point as seen in the third picture.
  • Lift the car enough to place a jack stand underneath a flat portion of the frame rail just behind the control arm bushing.
  • Gently allow the car to fall onto the jackstand, lifting the car and re-adjusting its position as necessary.
  • Once all of the weight has been transferred to the jack stand, tighten the release plug on the jack and leave it positioned under the jack point as seen in the third picture.
  • To be safe, jack stands should never be the only thing holding your car up. Always leave the jack up against the jack point in case the jack stand fails.
Insertar traducción aquí
