Saltar al contenido principal
Inglés
Español
Paso 2
Jacking up the car is not strictly necessary to change the oil on all E30s. I have lowered my car, so a drain pan will not fit under it as it sits on the ground. When my car was at stock ride height, I was able to change the oil without jacking it up by using a low profile drain pan.
Jacking Up the Car
  • Jacking up the car is not strictly necessary to change the oil on all E30s. I have lowered my car, so a drain pan will not fit under it as it sits on the ground. When my car was at stock ride height, I was able to change the oil without jacking it up by using a low profile drain pan.
  • Before lifting the car with a jack, be sure the car is in first gear for manual transmission cars or in park for automatic transmission cars.
  • Additionally, be sure to firmly apply the emergency brake.
  • You may also wish to put chocks behind the rear tires to keep the car from rolling. My emergency brake system is brand new, so I don't usually use chocks. If you are unsure, either use your factory wheel chock or put a brick/4x4 behind one of the rear tires.
Insertar traducción aquí
