Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
Use the small iPod opening tool to release the brown clamp holding the hard drive cable in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable. Slide the orange hard drive ribbon cable directly out of its connector. The cable may be attached to the logic board with some adhesive. If the cable doesn't immediately come free, carefully pull up on the cable to loosen the adhesive.
  • Use the small iPod opening tool to release the brown clamp holding the hard drive cable in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable.
  • Slide the orange hard drive ribbon cable directly out of its connector. The cable may be attached to the logic board with some adhesive. If the cable doesn't immediately come free, carefully pull up on the cable to loosen the adhesive.
Usa una pequeña espátula de apertura de plástico para soltar el cerrojo marrón que sujeta el cable plano del disco duro. La pestaña girará hasta 90 grados hacia la pantalla, liberando el cable plano.
Desliza el cable plano naranja directamente hacia afuera de su conector. El cable puede estar adherido a la tarjeta lógica con algo de pegamento. Si el cable no sale inmediatamente, jálalo con cuidado hacia arriba para aflojar el pegamento.
