Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Pull the vibrator motor connector straight away from its socket on the USB connector board. Remove the USB connector board from the TouchPad. NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
  • Pull the vibrator motor connector straight away from its socket on the USB connector board.
  • Remove the USB connector board from the TouchPad.
  • NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
Insertar traducción aquí
