Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera.  It should slide forward and unlock the clips holding it in place. Then it should be easy to simply lift the rear face plate up and remove it.
  • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
  • Then it should be easy to simply lift the rear face plate up and remove it.
Insertar traducción aquí
