Saltar al contenido principal
Inglés
Español
Paso 2
Insert the tip of a spudger into the slot in the bottom of the Circle Pad and under the plastic ring. Use a prying motion to remove the plastic ring from underneath the bottom of the Circle Pad.
  • Insert the tip of a spudger into the slot in the bottom of the Circle Pad and under the plastic ring.
  • Use a prying motion to remove the plastic ring from underneath the bottom of the Circle Pad.
  • It is all right if the ring is slightly bent by the spudger during removal. As long as it is not torn, the ring will still perform its intended duty.
Insertar traducción aquí
