Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 15 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up. Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board. Remove the Wi-Fi board from the device.
  • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
  • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
  • Remove the Wi-Fi board from the device.
Insertar traducción aquí
