Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Note the digitizer cable coming through to the back as it may be hard to see! Carefully thread this piece through its slot and separate the glass panel from the device frame. If you are simply trying to replace a broken screen, you may stop here in this guide and reverse the steps to reassemble your Amazon Fire. Try to preserve as much of the double-sided foam adhesive as possible, since you will need it to reinstall the replacement screen.
  • Note the digitizer cable coming through to the back as it may be hard to see! Carefully thread this piece through its slot and separate the glass panel from the device frame.
  • If you are simply trying to replace a broken screen, you may stop here in this guide and reverse the steps to reassemble your Amazon Fire.
  • Try to preserve as much of the double-sided foam adhesive as possible, since you will need it to reinstall the replacement screen.
Nota que el cable del digitalizador pasa a través del marco hacia la parte trasera, ya que puede ser difícil verlo. Saca cuidadosamente esta pieza a través de la rendija y separa el panel de vidrio del marco del dispositivo.
Si solamente estás tratando de reemplazar una pantalla rota, puedes detenerte aquí en esta guía y ejecutar los pasos en reversa para re-ensamblar su Amazon Fire.
[* red] Note the digitizer cable coming through to the back as it may be hard to see! Carefully thread this piece through its slot and separate the glass panel from the device frame.
[* icon_note] If you are simply trying to replace a broken screen, you may stop here in this guide and reverse the steps to reassemble your Amazon Fire.
[* icon_note] Try to preserve as much of the double-sided foam adhesive as possible, since you will need it to reinstall the replacement screen.
