Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Use a heating tool such as an iOpener or Heat gun around the edges of the Amazon Fire's glass screen. The iOpener may take longer to use. However, a heat gun can warp the plastic if used incorrectly. As you heat the edges, use a separator tool such as a guitar pick  to  lift the glass panel up and hold it up as you work around the device. Do not use a separation tool on the top edge of the device where the front camera would be; the digitizer cable is located in this location and can easily be severed. Instead, work in a U shape until you have 3 sides lifted from the frame
  • Use a heating tool such as an iOpener or Heat gun around the edges of the Amazon Fire's glass screen. The iOpener may take longer to use. However, a heat gun can warp the plastic if used incorrectly.
  • As you heat the edges, use a separator tool such as a guitar pick to lift the glass panel up and hold it up as you work around the device.
  • Do not use a separation tool on the top edge of the device where the front camera would be; the digitizer cable is located in this location and can easily be severed. Instead, work in a U shape until you have 3 sides lifted from the frame
  • Be patient with this step because it can be very time consuming and remember to use proper safety gear when using a heating device.
Usa una herramienta de calor como el iOpener o una pistola de calor alrededor de los bordes del vidrio de la pantalla del Amazon Fire. Esta operación puede llevar más tiempo con el iOpener. Sin embargo, una pistola de calor puede deformar el plástico si se usa incorrectamente.
A medida que vaya calentado los bordes, usa una herramienta de separación como el pico de guitarra para levantar el panel de vidrio y asegurarlo mientras trabajas alrededor del dispositivo.
No uses una herramienta de separación en el borde superior del dispositivo, donde se puede encontrar la cámara; el cable del digitalizador está localizado en esta parte y puede ser cortado fácilmente. En vez de esto, trabaja en forma de U hasta que tengas 3 lados levantados del marco.
Sé paciente con este paso porque puede tardar mucho tiempo y recuerda usar accesorios de protección cuando utilices un dispositivo para calentar.
