Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 5
  • The volume and power buttons must both be repositioned in order to remove the motherboard.
  • To reposition the power and volume buttons, use the iFixit Opening Tool to pull the plastic casing upwards. Then, remove the casing completely.
  • Make sure that both the volume and the power buttons are free from the plastic casing before separating the motherboard from its case.
  • Be very careful when repositioning the volume buttons, since the fragile digitizer ribbon cable runs from the motherboard to the digitizer right next to the volume buttons. It is very easy to damage the ribbon cable while working in this area.
Los botones de volumen y encendido deben ser reposicionados para poder remover la placa madre.
Para volver a colocar los botones de encendido y volumen, usa la herramienta de apertura de iFixit para halar la carcasa de plástico hacia arriba. Luego, retira la carcasa por completo.
Asegúrate que tanto el botón de volumen como el de encendido estén liberados de la carcaza de plástico antes de separar la placa madre de la carcaza.
[* black] The volume and power buttons must both be repositioned in order to remove the motherboard.
[* black] To reposition the power and volume buttons, use the iFixit Opening Tool to pull the plastic casing upwards. Then, remove the casing completely.
[* icon_note] Make sure that both the volume and the power buttons are free from the plastic casing before separating the motherboard from its case.
[* icon_caution] Be very careful when repositioning the volume buttons, since the fragile digitizer ribbon cable runs from the motherboard to the digitizer right next to the volume buttons. It is very easy to damage the ribbon cable while working in this area.
