Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 4
If necessary, carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case. Carefully push the trackpad connector and cable down through the slot cut into the upper case. It may be necessary to use a spudger to help get the trackpad connector past the edge of the logic board.
  • If necessary, carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
  • Carefully push the trackpad connector and cable down through the slot cut into the upper case.
  • It may be necessary to use a spudger to help get the trackpad connector past the edge of the logic board.
  • Once the cable has been completely pulled through its slot in the upper case, pull the trackpad away from the outer edge of the upper case and remove it from the machine.
Si es necesario, desalojar con cuidado borde del trackpad mas cercano al teclado de su cavidad en la parte superior empujando lejos de los soportes conectados a la caja superior.
Empuja con cuidado el conector del trackpad y el cable hacia abajo a través de la ranura cortada en la caja superior.
Puede ser necesario utilizar un apudger para ayudar a obtener el conector del trackpad mas allá del borde de la placa lógica.
Una vez que el cable ha sido completamente retirado a través de su ranura en la caja superior, tira del trackpad lejos del borde exterior de la caja superior y retíralo de la máquina.
