Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
The display should now be free of the body of the Surface Pro. Lift it up and away from the rest of the device. Before installing a new display, check it carefully to see if any parts need to be transferred over from the back of the old display to the new display. In particular, you may need to transfer over the NTrig board in the corner by disconnecting the two attached ribbon cables and using heat and gentle prying to carefully separate the glue securing the board. To replace the adhesive securing the display, carefully remove any old adhesive from both the device and the back of the display. Clean and prep the surface with isopropyl alcohol and a lint-free cloth, swiping the cloth in one direction (not back and forth). Apply a strong double-sided tape, such as 2 mm Tesa 61395.
  • The display should now be free of the body of the Surface Pro. Lift it up and away from the rest of the device.
  • Before installing a new display, check it carefully to see if any parts need to be transferred over from the back of the old display to the new display. In particular, you may need to transfer over the NTrig board in the corner by disconnecting the two attached ribbon cables and using heat and gentle prying to carefully separate the glue securing the board.
  • To replace the adhesive securing the display, carefully remove any old adhesive from both the device and the back of the display. Clean and prep the surface with isopropyl alcohol and a lint-free cloth, swiping the cloth in one direction (not back and forth). Apply a strong double-sided tape, such as 2 mm Tesa 61395.
La pantalla debería estar libre del cuerpo del Surface Pro. retíralo.
Antes de instalar una nueva pantalla, verifíquela cuidadosamente para ver si es necesario transferir alguna parte desde la parte posterior de la pantalla anterior a la nueva. En particular, es posible que deba transferir la placa NTrig que se encuentra en la esquina desconectando los dos cables,utilizando una pistola de calor y haciendo palanca suavemente.
Para reemplazar el adhesivo que asegura la pantalla, retire con cuidado cualquier adhesivo viejo tanto del dispositivo como de la parte posterior de la pantalla. Limpie y prepare la superficie con alcohol isopropílico y un paño sin pelusas, deslizando el paño en una dirección (no de un lado a otro). Aplique una cinta de doble cara, como Tesa 61395 de 2 mm.
