Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 3
Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame. If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display. Insert an opening pick into the gap.
  • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
  • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
  • Insert an opening pick into the gap.
  • There are tabs on the upper right side and upper left side where it is easier to get a tool under the display.
  • Slide an opening pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
  • The tape is much thinner on the bottom edge than the other three sides. Do not push the tool in too far or you will damage the screen permanently.
  • Work carefully—the glass is thin and will crack easily if you try to force it.
  • Separate the top edge last. There are antennas on both sides, so be careful not to damage them. If needed, you can use a bit of isopropyl alcohol to help weaken the adhesive.
Utiliza una ventosa o el iSclack para retirar el cristal y crear un pequeño hueco entre el cristal y el marco metalico.
Si tu pantalla está muy dañada, la ventosa podría no succionarla. Podría ayudarte primero cubrir la pantalla con una capa de cinta. Alternativamente, podrías utilizar superglue para enganchar la ventosa al display
Introduce la herramienta de apertura en el hueco.
Hay pestañas en la parte superior derecha y la parte superior izquierda donde es más fácil introducir la herramienta de apertura.
Desliza la herramienta de apertura por los lados y la parte inferior del display para cortar el pegamento. Aplica calor si es necesario.
La cinta es mucho más fina en el borde inferior que en los otros tres lados. No empujes la herramienta con demasiada fuerza o dañarás la pantalla.
Trabaja con cuidado — el cristal es fino y podría romperse fácilmente si lo fuerzas.
Separa el borde superior al final, Hay antenas en ambos lados, así que ten cuidado de no dañarlos. Si es necesario, puedes utilizar un poco de alcohol isopropílico para debilitar el adhesivo.
