Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Pull the ribbon cable out of the connector with a pair of tweezers.
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Pull the ribbon cable out of the connector with a pair of tweezers.
  • Grasp the ribbon cable as close to the connector as possible with the tweezers to avoid tearing it.
Insertar traducción aquí
