Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard. Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector. Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
  • Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard.
  • Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
Insertar traducción aquí
