Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 26
The chip on the bottom center that looks blank in our image actually has this text: MARVELL, W8686B13, 702AUUP. This is Marvell's 802.11b/g 18.4mm2 chip.
  • The chip on the bottom center that looks blank in our image actually has this text: MARVELL, W8686B13, 702AUUP. This is Marvell's 802.11b/g 18.4mm2 chip.
  • The chip in the upper right is a Skyworks GSM/Edge Power amplifier (SKY77340).
  • The silver chip to the left of the Skyworks chip reads CSR 41814 3A06U K715FB. This is a CSR BlueCore4-ROM WLCSP single chip radio and baseband IC for Bluetooth 2+EDR.
  • The chip covered by the white sticker in the photo has the part numbers 338S0289 and 8G60710 on it. EETimes claims this is an Infineon M1817A11.
  • The chip with the blue dot on it is rumored to be an Intel Wireless Flash stacked 32 Mb NOR + 16 Mb SRAM chip. Part numbers 1030W0YTQ2, 5716A673, and Z717074A. EE Times adds the part #PF38F1030W0YTQ2.
  • The chip in the lower right reads 338S 0297 G0719. Some claim this is an Apple-branded chip, but it's purpose is currently unknown.
  • The chip in the lower left is an Infineon PMB8876 S-Gold 2 multimedia engine. Part numbers: 337S3235, 60708, and EL629058S03.
  • If you have any additional information about any iPhone chips or internals, please e-mail us and we'll post the information anonymously.
El chip en el centro inferior que se ve en blanco en nuestra imagen en realidad tiene este texto: MARVELL, W8686B13, 702AUUP. Este es el chip de Marvell 802.11b / g 18.4mm2.
El chip en la parte superior derecha es un amplificador de potencia Skyworks GSM / Edge (SKY77340).
El chip de plata a la izquierda del chip Skyworks lee CSR 41814 3A06U K715FB. Esta es una radio de un solo chip CSR BlueCore4-ROM WLCSP e IC de banda base para Bluetooth 2 + EDR.
El chip cubierto por la etiqueta blanca en la foto tiene los números de parte 338S0289 y 8G60710 en ella. EETimes afirma que este es un Infineon M1817A11.
Se rumorea que el chip con el punto azul en él es un chip Intel Wireless Flash de 32 Mb NOR + 16 Mb SRAM. Números de pieza 1030W0YTQ2, 5716A673 y Z717074A. EE Times agrega la parte # PF38F1030W0YTQ2.
El chip en la parte inferior derecha lee 338S 0297 G0719. Algunos afirman que este es un chip de la marca Apple, pero su propósito es actualmente desconocido.
El chip en la parte inferior izquierda es un motor multimediaInfineon PMB8876 S-Gold 2. Números de pieza: 337S3235, 60708 y EL629058S03.
Si tiene información adicional sobre cualquier chip o dispositivo interno de iPhone, envíenos un correo electrónico y publicaremos la información de forma anónima.
