Saltar al contenido principal
Inglés
Español
Traduciendo paso 11
Paso 11
Using the flat end of a spudger, carefully wedge the motherboard from the case. Be patient, using gentle and even force, while wedging the motherboard out of the midframe with the spudger.  Excessive flexing of the board may cause damage to components or circuit traces. Using your fingers, gently remove the motherboard out of the device.
  • Using the flat end of a spudger, carefully wedge the motherboard from the case.
  • Be patient, using gentle and even force, while wedging the motherboard out of the midframe with the spudger. Excessive flexing of the board may cause damage to components or circuit traces.
  • Using your fingers, gently remove the motherboard out of the device.
  • Once the motherboard is removed, the device should look like as illustrated in the third picture.
Insertar traducción aquí
