Saltar al contenido principal
Inglés
Español
Paso 5
Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame. For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other. Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
  • Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
  • For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
  • Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
Insertar traducción aquí
