Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Detach a pin connector at the top of the device using a metal spudger to open up the inner components. Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device. Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
  • Detach a pin connector at the top of the device using a metal spudger to open up the inner components.
  • Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
Insertar traducción aquí
