Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Press both audio ports down slightly, then lift the audio port assembly out of the outer case. A pair of tweezers is helpful to put the ports back in place. First insert the lower tab into the bracket on the outer case, then fasten the screw to secure the jack to the outer case.
  • Press both audio ports down slightly, then lift the audio port assembly out of the outer case.
  • A pair of tweezers is helpful to put the ports back in place. First insert the lower tab into the bracket on the outer case, then fasten the screw to secure the jack to the outer case.
  • During reinstallation, it may be helpful to plug in a pair of headphones to each jack before tightening them down completely.
Insertar traducción aquí
