Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case. Remove the antenna/camera cable retainer from the upper case.
  • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
  • Remove the antenna/camera cable retainer from the upper case.
  • During reassembly, place the nearby metal grounding tab on top of the hole that the Phillips screw goes into, and then install the screw.
Insertar traducción aquí
