Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 21 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 15
Paso 15
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal. If necessary, use the flat end of a spudger to separate the microphone from the upper case. Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
  • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
  • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
  • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
Insertar traducción aquí
