Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 14
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the top left portion of the upper case. Remove the antenna/camera cable retainer from the upper case.
  • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the top left portion of the upper case.
  • Remove the antenna/camera cable retainer from the upper case.
  • Check your new part: The antenna cable and plate attached to the upper case may need to be transferred. Take care peeling the metal plate off, an adhesive is used to hold it in place.
Insertar traducción aquí
