Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 20 guías que incluyan este paso.
Inglés
Español
Paso 2
Use the flat end of a spudger to disconnect the left fan connector from the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Utiliza la parte plana del spudger para desconectar el conector de ventilador izquierdo de la tarjeta lógica
Facilitará tu trabajo el girar el spudger axialmente desde abajo de los cables del ventilador para liberar el conector (este conector es de presión vertical, no de enchufe tipo toma corriente).
El zócalo y conector del ventilador pueden verse en la 2º y 3º imagen. TEN cuidado de no romper el zócalo plástico del ventilador en la tarjeta lógica mientras utilizas el spudger para levantar rectamente y hacia afuera el conector del ventilador. El zócalo es igual aunque en la segunda foto difiera la placa electrónica.
