Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable. Use the tip of a spudger to flip the ZIF connector on the hard drive cable. Gently pull the sensor bracket cable out of the ZIF connector.
  • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
  • Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
  • Gently pull the sensor bracket cable out of the ZIF connector.
  • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
  • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
Insertar traducción aquí
