Saltar al contenido principal
Inglés
Español
Paso 2
Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard. Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible. Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
  • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
Usa la parte plana de un spudger para hacer palanca de la parte trasera del Circle Pad para sacarla de la placa madre.
Levanta el joystick Circle Pad fuera de la placa base y colócalo en su parte trasera para tener acceso a su conector.
