Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
Look for liquid or residue between the touchscreen and LCD. This phone shows water build-up between the touchscreen and LCD, and most likely contains more liquid inside. In this case, there is no obvious damage or corrosion in the external dock connector. There is no obvious damage or corrosion in the headphone jack.
Assessing visible external damage
  • Look for liquid or residue between the touchscreen and LCD. This phone shows water build-up between the touchscreen and LCD, and most likely contains more liquid inside.
  • In this case, there is no obvious damage or corrosion in the external dock connector.
  • There is no obvious damage or corrosion in the headphone jack.
Busque líquido o residuo entre la pantalla táctil y la pantalla LCD. Este teléfono muestra la acumulación de agua entre la pantalla táctil y la pantalla LCD, y probablemente contiene más líquido dentro.
En este caso, no hay daños evidentes o corrosión en el conector de la base externa.
No hay daños evidentes o corrosión en la toma de los auriculares.
