Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 31 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
Levanta el disco duro desde el borde más cercano a la placa lógica y extraelo un poco del hueco.
El disco duro está conectado por un solo cable de alimentación / datos SATA; no intentes extraerlo completamente del iMac todavía.
