Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 27 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Levanta la pantalla fuera del marco y quítala del iMac.
Puede ser necesario levantarla lentamente de un lado, para despegar el adhesivo remanente.
Ten mucho cuidado cuando lleves la pantalla; es grande, pesada, y está hecha de vidrio.
Luego de que el adhesivo es cortado, no puede ser usado de nuevo para volver a sellar la pantalla en su lugar. Sigue esta guía para reemplazar las tiras adhesivas que aseguran la pantalla a la carcasa posterior.
[* black] Lift the display up from the frame and remove it from the iMac.
[* black] It may be necessary to slowly lift from one side to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass.
[* icon_reminder] After the adhesive is cut, it cannot be used to re-seal the display in place. Follow [guide|64210|this guide|new_window=trueguide|137411|this guide] to replace the adhesive strips that secure the display to the rear enclosure.
