Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 6
Ribbon cable "3" is held in place by a FPC style connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism. The FPC locking latch is very delicate and is typically a different color than the body of the connector. (see the detail image of FPC connector open and closed)
  • Ribbon cable "3" is held in place by a FPC style connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism.
  • The FPC locking latch is very delicate and is typically a different color than the body of the connector. (see the detail image of FPC connector open and closed)
  • Slide the ribbon cable out of the connector, and remove the display assembly from the iPhone.
  • It's impossible to properly reinsert a ribbon into an FPC connector unless the lock is disengaged. Make sure the locking latch is open when attaching/detaching the cable.
El cable de cinta "3" se mantiene en su lugar mediante un conector de estilo FPC. Debe desbloquear este conector antes de deslizar el cable de cinta. El mecanismo de bloqueo está en el lado opuesto de donde se inserta el cable - gira 90 grados hacia arriba. Utilice un spudger de plástico para levantar el mecanismo de bloqueo.
El cierre de bloqueo de FPC es muy delicado y es típicamente un color diferente al cuerpo del conector. (Ver la imagen detallada del conector FPC abierta y cerrada)
Deslice el cable plano del conector y retire el conjunto de la pantalla del iPhone.
Es imposible reinsertar correctamente una cinta en un conector FPC a menos que la cerradura esté desconectada. Asegúrese de que el pestillo de bloqueo esté abierto al conectar / desacoplar el cable.
