Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 3
Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches. Remove both screws, then carefully lift the side panel off. Underneath the side panel, there is a .07 inch screw. Remove it.
  • Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches.
  • Remove both screws, then carefully lift the side panel off.
  • Underneath the side panel, there is a .07 inch screw. Remove it.
Insertar traducción aquí
