Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before taking apart your device,  ensure that it is turned off and that your anti-static wrist strap is secured to a ground. Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands. You will not need to pry the case off.
  • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
  • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
  • You will not need to pry the case off.
Insertar traducción aquí
