Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Use the flat end of the plastic spudger to pry the battery apart from the rest of the device. An alternative method is to loosen the battery using the plastic spudger, and then to remove the battery by pulling on the paper tab that says "Pull (Hands Only)." Once the back cover and battery are removed, the device should look like as illustrated in the second picture.
  • Use the flat end of the plastic spudger to pry the battery apart from the rest of the device.
  • An alternative method is to loosen the battery using the plastic spudger, and then to remove the battery by pulling on the paper tab that says "Pull (Hands Only)."
  • Once the back cover and battery are removed, the device should look like as illustrated in the second picture.
Usa el extremo plano del spudger de plástico para separar la batería del resto del dispositivo.
Un método alternativo es aflojar la batería usando el spudger de plástico y luego quitar la batería tirando de la pestaña de papel que dice "Tira (solo con las manos)".
Una vez que se quitan la tapa posterior y la batería, el dispositivo debe verse como se ilustra en la segunda imagen.
