Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 16
Peeling up those pesky soft button LED cables lets us finally free the daughterboard. Just for those of you keeping score, this messy situation prevents easy replacement of: display and digitizer (of course), USB port, microphone, and soft button LEDs. If you need to replace the charging port, unless you have some microsoldering skills, you have two options: sacrifice those soft button LEDs or replace your display in the process.
  • Peeling up those pesky soft button LED cables lets us finally free the daughterboard.
  • Just for those of you keeping score, this messy situation prevents easy replacement of: display and digitizer (of course), USB port, microphone, and soft button LEDs.
  • If you need to replace the charging port, unless you have some microsoldering skills, you have two options: sacrifice those soft button LEDs or replace your display in the process.
  • Remember that fake "midframe" made of antennas? Turns out the S7 just buried its midframe deeper, and adhered the display to it, rather than secure its display assembly to a midframe with screws.
  • This beefs up the S7’s waterproofiness, but means more of a fight to repair the thing should you suffer non-water related troubles.
Sacar esos cables molestos de LED de botones blandos nos permite finalmente liberar a la placa madre
Para aquellos a los que les encanta llevar la cuenta, esta situación desordenada previene el fácil reemplazo de: pantalla y digitalzador (por supuesto), puerto USB, micrófono y LEDs de botones blandos.
Si necesitas reemplazar el puerto de carga, a menos que tengas habilidades de microsoldadura, tienes dos opciones: sacrificar esos LEDs de botones blandos o reemplazar tu pantalla en el proceso.
¿Recuerdas ese marco "medio falso" hecho de antenas? Resulta ser que el S7 ha enterrado su marco medio más profundamente y ha adherido la pantalla, en vez de sujetar su ensamblaje de pantalla al marco medio con tornillos.
Esto refuerza la impermeabilidad del S7 pero significa que deberemos luchar más para reparar si es que sufres de problemas que no sean de agua.
