Saltar al contenido principal
Inglés
Español
Paso 4
If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case. Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or  hair dryer.
  • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
  • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
  • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
  • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • Do not pry against the logic board or you may damage the phone.
  • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
  • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
  • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
Si removiste con éxito las tiras adhesivas, ve al siguiente paso. En caso contrario, necesitarás extraer la batería de la carcasa inferior.
Prepara el iOpener y aplícalo sobre la carcasa trasera, directamente sobre la batería. De forma alternativa, puedes aplicar calor con una pistola de calor o un secador de pelo.
Después de aproximadamente un minuto, voltea el teléfono y usa una tarjeta de plástico para romper cualquier adhesivo restante que haya detrás de la batería.
No insertes tu tarjeta en el área entre el botón de bajar volumen (-) y el borde superior de la batería, o puedes dañar el cable de control de volumen.
No hagas palanca contra la placa base o puedes dañar el teléfono.
Mantén la tarjeta lo más plana posible para evitar doblar la batería, que podría dañarla y causar la liberación de químicos peligrosos o incendiarse. No uses ninguna herramienta afilada para extraer la batería.
Alternativamente, un pedazo de hilo dental puede ser usado para separar la batería de la carcaza. Otra alternativa más fuerte es una cuerda de guitarra como una cuerda 0.009 E de un set de 12 cuerdas.
Pasa el hilo dental o la cuerda detrás de las esquinas superiores de la batería, junta los extremos, envuélvalos alrededor de un paño doblado y tira uniformemente.
