Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting. Do not pull to remove the casing until all sides are loose. You may break or crack the case.
  • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
  • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
  • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
  • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Insertar traducción aquí
