Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 6
If you're just trying to remove the rear panel, you can skip Steps 30 and 31. If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If you're just trying to remove the rear panel, you can skip Steps 30 and 31.
  • If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack.
  • Remove the single Phillips screw nearest to the hold switch.
  • Lift the plastic portion of the Hold switch away from the orange ribbon cable.
  • Ensure that the black notch lines up with the gray slider during reassembly of the switch (see picture 2).
Insertar traducción aquí
