Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Be careful of LCD connector on the underside of the board through all of these steps (see green). Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong. Be careful to remove the display first from the right side as there are clips along the left side.
Logic Board
  • Be careful of LCD connector on the underside of the board through all of these steps (see green).
  • Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong.
  • Be careful to remove the display first from the right side as there are clips along the left side.
  • Ensure not to damage the LCD cable, remove once accessible by releasing the brown clasp from indicated side.
Insertar traducción aquí
