Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
  • Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
  • One 5.0 mm screw with a 2.0 mm long shoulder
  • One 4.0 mm screw with a wide head
  • One 4.4 mm screw
Remueve los siguientes tres tornillos que sujetan el ventilador derecho a la placa lógica
Un tornillo Torx T5 de 5.00 mm con un hombro de 2.0 mm de largo
Un tornillo Torx T5 de 4.0 mm con una cabeza ancha.'
Un tornillo Torx T5 de 4.4 mm
-[* black] Remove the following three screws securing the right fan to the logic board:
- [* red] One 5.0 mm T5 Torx screw with a 2.0 mm long shoulder
- [* orange] One 4.0 mm T5 Torx screw with a wide head
- [* yellow] One 4.4 mm T5 Torx screw
+[* black] Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
+ [* red] One 5.0 mm screw with a 2.0 mm long shoulder
+ [* orange] One 4.0 mm screw with a wide head
+ [* yellow] One 4.4 mm screw
