Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
Lift up and remove the earpiece speaker bracket, peeling up the bracket gasket as you go. Peel up the gasket carefully, as it is thin and can tear easily. Peel up the gasket carefully, as it is thin and can tear easily.
  • Lift up and remove the earpiece speaker bracket, peeling up the bracket gasket as you go.
  • Peel up the gasket carefully, as it is thin and can tear easily.
Levanta y retira el soporte del altavoz del auricular, despegando la junta de soporte a medida que avanzas.
Pelar la junta con cuidado, ya que es delgada y se puede cortar con facilidad .
