Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the end of the AirPort board up enough to pass over the heat sink directly behind it. Do not lift the AirPort board too high, or you could damage the contacts or socket. Pull the AirPort board straight out of its socket on the logic board.
  • Lift the end of the AirPort board up enough to pass over the heat sink directly behind it.
  • Do not lift the AirPort board too high, or you could damage the contacts or socket.
  • Pull the AirPort board straight out of its socket on the logic board.
  • There is a slightly adhesive thermal pad beneath the AirPort board. Be sure to reapply this when reinstalling the board, or transfer it to your replacement board.
Levante el extremo de la placa AirPort lo suficiente para pasar sobre el disipador de calor directamente detrás de él.
No levante la placa AirPort demasiado puede dañar los contactos o el zócalo.
Levanta la placa AirPort directamente de su zócalo en la placa lógica
Hay una almohadilla termica ligeramente adhesiva debajo de la placa AirPort. Asegúrese de aplicar esto al reinstalar la placa, o transferirlo a su placa de reemplazo.
