Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 8
Remove the three 5.0 mm screws by the micro-USB, micro-HDMI and remote ports. Remove the screw hidden behind the port cover hinge. The port cover assembly should come off with ease. If it is stuck, try prying with plastic shims.
  • Remove the three 5.0 mm screws by the micro-USB, micro-HDMI and remote ports.
  • Remove the screw hidden behind the port cover hinge.
  • The port cover assembly should come off with ease. If it is stuck, try prying with plastic shims.
Insertar traducción aquí
