Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Grab the metal frame with the flash assembly that was removed from around the lens assembly. Remove the 2 mm screw on the circuit board using a Phillips #00 screwdriver.
  • Grab the metal frame with the flash assembly that was removed from around the lens assembly.
  • Remove the 2 mm screw on the circuit board using a Phillips #00 screwdriver.
  • Lift and remove the circuit board from the flash assembly.
Insertar traducción aquí
