Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 15
Be careful not to pinch the cable while pulling it out because it can easily be damaged. It is helpful to pull it out by the tabs that are built into the connector ribbon. Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
  • Be careful not to pinch the cable while pulling it out because it can easily be damaged. It is helpful to pull it out by the tabs that are built into the connector ribbon.
  • Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
  • Remove the small cable towards the top by pulling it straight out of its connector using tweezers or your fingers.
  • Remove both Screws on the bottom side of the motherboard
Insertar traducción aquí
