Saltar al contenido principal
Inglés
Español
Paso 9
If your PS4 will not turn on (or turns on and right back off) after you have already had it working, try taking the cover back off and tighten the screws on the plate. If the screws are too tight the PS4 will not work at all. Slightly loosen until the system turns on. Be cautious about having the console plugged in. Possible but not recommended.
IF ALL ELSE FAILS
  • If your PS4 will not turn on (or turns on and right back off) after you have already had it working, try taking the cover back off and tighten the screws on the plate. If the screws are too tight the PS4 will not work at all. Slightly loosen until the system turns on. Be cautious about having the console plugged in. Possible but not recommended.
Si su PS4 no se enciende o se enciende y se apaga de nuevo después de haberlo tenido funcionando, intente quitar la tapa y apriete los tornillos. Si los tornillos estan demasiado apretados el PS4 no funcionará en absoluto. Afloje ligeramente hasta que el sistema se encienda. Tenga cuidado con la conexión de la consola. Posible pero no recomendado.
