Saltar al contenido principal
Inglés
Español
Paso 8
After third washer has been installed and the screws have been tightened touch the power pad on the motherboard. If the PS4 makes no noise and shows no lights then the screws are too tight...loosen screws very slightly (about 1/8 turn) and try to power it on again. Do this until the console powers on.
Power Console On
  • After third washer has been installed and the screws have been tightened touch the power pad on the motherboard.
  • If the PS4 makes no noise and shows no lights then the screws are too tight...loosen screws very slightly (about 1/8 turn) and try to power it on again. Do this until the console powers on.
  • If the console still turns on and back off after these steps have been done then this fix will not work for your PS4.
Después de instalar la tercera arandela y apretar los tornillos, toque la almohadilla de alimentación de la placa base.
Si el PS4 no hace ruido y no muestra luces, entonces los tornillos están demasiado apretados ... afloje los tornillos muy ligeramente (aproximadamente 1/8 de vuelta) e intente volver a encenderlo. Haga esto hasta que se encienda la consola.
Si la consola se enciende y se apaga después de que se hayan realizado estos pasos, esta corrección no funcionará para tu PS4.
